Version: 8.1
system.db.removeDatasource
Removes a database connection from Ignition.
Permission Type: Datasource Management
system.db.removeDatasource(name)
StringnameThe name of the database connection in Ignition.
Nothing
Code Snippet - Removing Database from Gateway
# This results in the connection named MySQL being removed.
system.db.removeDatasource("MySQL")
