system.db.setDatasourceMaxConnections
Sets the Max Active and Max Idle parameters of a given database connection.
Permission Type: Datasource Management
system.db.setDatasourceMaxConnections(name, maxConnections)
Type | Parameter | Description |
String | name | The name of the database connection in Ignition. |
Integer | maxConnections | Sets the Max Active and Max Idle parameters of a given database connection. |
Nothing
Code Snippet - Setting the Max Connections of a Data Source
# Example 1: Enable a connection
system.db.setDatasourceMaxConnections("MySQL", 20)
