system.db.runNamedQuery
Runs a Named Query and returns the results. Note that the number of parameters in the function is determined by scope. Both versions of the function are listed below.
Project Scope Syntax​
system.db.runNamedQuery(path, [parameters], [tx], [getKey])
| String | path | The path to the named query to run. Note that this is the full path to the query, including any folders. |
| Dictionary[String, Any] | parameters | A Python dictionary of parameters for the Named Query to use. [optional] |
| String | tx | An transaction ID, obtained from beginNamedQueryTransaction. If blank, it will not be part of a transaction. [optional] |
| Boolean | getKey | Only used for Update Query types. A flag indicating whether or not the result should be the number of rows affected (getKey=0) or the newly generated key value that was created as a result of the update (getKey=1). Not all databases support automatic retrieval of generated keys. [optional] |
PyDataset -
Any - Prior to 8.1.29, the exact object returned depends on the Query Type property of the Named Query. Query Types are selected on the Authoring Tab of a Named Query, and typically return the following:
- Query: A dataset
- Scalar Query: An integer representing the number of rows affected
- Update Query: An object matching the data type of the value returned
Vision Client, Perspective Session
Gateway Scope Syntax​
system.db.runNamedQuery(project, path, [parameters], [tx], [getKey])
| String | project | The project name the query exists in. |
| String | path | The path to the Named Query to run. Note that this is the full path to the query, including any folders. |
| String | tx | An optional transaction ID, obtained from beginNamedQueryTransaction. If blank, will not be part of a transaction. [optional] |
Any - The results of the query. The exact object returned depends on the Query Type property of the Named Query. Query Types are selected on the Authoring Tab of a Named Query, and typically return the following:
- Query: A dataset
Gateway
# This example runs a Named Query without any parameters in the Project scope.
# Request the Named Query to execute.
system.db.runNamedQuery("folderName/myNamedQuery")
# This example runs a Named Query while passing some parameters in the Project scope.
# The Named Query is assumed to have two parameters already defined on the Named Query:
# param1 : A string
# param2 : An integer
# Create a Python dictionary of parameters to pass.
parameters = {"param1":"my string", "param2":10}
# Run the Named Query.
system.db.runNamedQuery("myUpdateQuery", parameters)
# This example runs a Named Query without any parameters in the Gateway scope.
system.db.runNamedQuery("ProjectName", "folderName/myNamedQuery")
