Version: 8.1
system.db.setDatasourceEnabled
Enables/disables a given database connection.
Permission Type: Datasource Management
system.db.setDatasourceEnabled(name, enabled)
StringnameThe name of the database connection in Ignition.
BooleanenabledEnables/disables a given database connection.
Nothing
Code Snippet - Enabling a Database Connection
# Enable the database named "MySQL"
system.db.setDatasourceEnabled("MySQL", 1)
Code Snippet - Disabling a Database Connection
# Disable the database named "MySQL"
system.db.setDatasourceEnabled("MySQL", 0)
