Version: 8.1
system.db.execSProcCall
New in 8.1.2
Executes a stored procedure call. The one parameter to this function is an SProcCall - a stored procedure call context. See the description of system.db.createSProcCall for more information and examples.
Restrictions Prior to 8.1.2​
This scripting function has no Client Permission restrictions on Ignition versions earlier than 8.1.2.
Restrictions for 8.1.2 and beyond​
Permission Type: Legacy Database Access
system.db.execSProcCall(callContext)
SProcCallcallContextA stored procedure call context, with any input, output, and/or return value parameters correctly configured. Use system.db.createSProcCall to create a call context.
Nothing
There are no code examples available for this function.
