Version: 8.1
system.db.runScalarQuery
Runs a query against a database connection just like the runQuery function, but only returns the value from the first row and column. If no results are returned from the query, the special value None is returned.
Permission Type: Legacy Database Access
Syntax - Gateway​
system.db.runScalarQuery(query, database, [tx])
StringqueryA SQL query that should be designed to return one row and one column.
StringdatabaseThe name of the database connection to execute against.
StringtxA transaction identifier. If omitted, the query will be executed in its own transaction. [optional]
Object - The value from the first row and first column of the results. - Returns None if no rows were returned.
Gateway
Syntax - Vision and Perspective​
system.db.runScalarQuery(query, [database], [tx])
StringdatabaseThe name of the database connection to execute against. If omitted or "", the project's default database connection will be used. [optional]
Any - The value from the first row and first column of the results. Returns None if no rows were returned.
Vision Client, Perspective Session
Code Snippet
# This code counts the number of active alarms and acknowledges them all if there is at least one.
numAlarms = system.db.runScalarQuery("SELECT COUNT(*) FROM alarmstatus " + "WHERE unacknowledged = 1")
if numAlarms > 0:
# There are alarms - acknowledge all of them
system.db.runUpdateQuery("UPDATE alarmstatus SET unacknowledged = 0")
Code Snippet
# This code reads a single value from a table and shows it to the user in a popup.
level = system.db.runScalarQuery("SELECT Level FROM LakeInfo WHERE LakeId='Tahoe'")
system.gui.messageBox("The lake level is: %d feet" % level)
