system.db.clearNamedQueryCache.md
New in 7.9.6
This clears the cache of a Named Query. If called from the Shared Scope (i.e., Tag Event Scripts, Alarm Pipelines, etc.) then the name of the project must be passed as a parameter.
Syntax - Project Scope​
system.db. clearNamedQueryCache(path)
StringpathThe Path to the named query we want to clear the cache of.
No Return Value
All
Syntax - Shared Scope​
system.db. clearNamedQueryCache(project, path)
StringprojectThe Project that contains the named query whose cache needs to be cleared.
No Return Value
All
Example #1
# Calling this simply clears all Named Query Caches.
# This example is being called from the Shared Scope. If called from the Project Scope, the projectName parameter should be omitted.
projectName = "myProject"
namedQueryPath = "folder/selectFromInventory"
system.db.clearNamedQueryCache(projectName, namedQueryPath)
Example #2
# If the same Named Queried is called multiple times with different parameters in a single script, then we can clear the caches once we're done with the following.
# This example assumes the script is running in the Project Scope. If called from the Shared Scope, the name of the project would need to be included.
namedQueryPath = "myUpdateQuery"
# This creates one cache.
params = {"param1":"A"}
system.db.runNamedQuery(namedQueryPath, params)
# This creates a separate cache.
params = {"param1":"B"}
# Clear all of the caches from the specified Named Query. Note that all caches are cleared, including those generated from elsewhere on the Gateway.
system.db.clearNamedQueryCache(namedQueryPath)
