system.db.dateFormat
This function is used to format Dates nicely as strings. It uses a format string to guide its formatting behavior. Learn more about date formatting in Dates
Expert Tip: This function uses the Java class java.text.SimpleDateFormat internally, and will accept any valid format string for that class.
system.db.dateFormat(date, formatPattern)
DatedateThe Date object that you'd like to format
StringformatPatternA format pattern string to apply.
String - The date as a string formatted according to the format pattern.
All
Example #1
# This example will display a message box on a button press that displays the selected date (without the time)
# from a Calendar component, in a format like "Feb 3, 2009"
date = event.source.parent.getComponent("Calendar").latchedDate
toDisplay = system.db.dateFormat(date, "MMM d, yyyy")
system.gui.messageBox("The date you selected is: %s" % toDisplay)
Example #2
# This example would do the same as the one above, but also display the time, in a format like: "Feb 3, 2009 8:01pm"
Example #3
# This example would take two dates from two Popup Calendar components, format them in a manner that the database understands,
# and then use them in a SQL query to limit the results to a certain date range.
startDate = event.source.parent.getComponent("StartDate").date
endDate = event.source.parent.getComponent("EndDate").date
startDate = system.db.dateFormat(startDate, "yyyy-MM-dd HH:mm:ss")
endDate = system.db.dateFormat(endDate, "yyyy-MM-dd HH:mm:ss")
query = ("SELECT * FROM mytable WHERE t_stamp >= '%s' AND t_stamp <= '%s'" % (startDate, endDate))
results = system.db.runQuery(query)
event.source.parent.getComponent("Table").data = results
