--- title: "system.db.setDatasourceEnabled" description: "Enables/disables a given database connection." --- # system.db.setDatasourceEnabled > Enables/disables a given database connection. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Datasource Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.db.setDatasourceEnabled(name, enabled)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `name` | The name of the database connection in Ignition. Boolean | `enabled` | Enables/disables a given database connection. ### Returns Nothing ### Scope All ## Code Examples ```python title="Example #1" # Example 1: Enable a connection system.db.setDatasourceEnabled("MySQL", 1) ``` ```python title="Example #2" # Example 2: Disable a connection system.db.setDatasourceEnabled("MySQL", 0) ```
