Connections - Designers
Designers​
The Designers page displays information on currently running Designer sessions. All the open Designers are displayed on the page along with some basic information about each session, such as what user is logged into each Designer session and the project they are currently working on. Clicking on the Details button to the right of a Designer session will display more information about that particular Designer. On the Details page, you can see session information, as well as what Designer locks the session currently has set. Locks are when a Designer is working on a particular page or set of pages, the system places a lock on those resources (i.e., window, pipelines, etc.,) to prevent other Designers from working on the same resource. There is also a log at the bottom of the page displaying any errors pertaining to that Designer session.
Connections list with designer
Designers Page​
The main Designers page has a list of all currently running Designer sessions, and some basic information about all of them.
Designer Stats​
AttributeDescription
Active DesignersNumber of active Designer connections.
Requests/SecNumber of requests running per second along with a trend showing the percentage of requests that completed in that time.
Designer Sessions​
FilterSearch criteria to filter for specific Designer sessions.
ViewThe number of Designer sessions to preview.
IdDesigner session id number.
UserName of the user logged into the Designer.
ProjectName of project the user is currently working on.
UptimeAmount of time the user is logged into the Designer session.
StatusIf the Designer is actively connected or not.
AddressThe IP Address and name of the computer running the Designer.
MemoryCurrent memory usage for the session.
Connections Designers Page
Designer Details​
The Designer Details page shows more in-depth information about that particular Designer session, with the most important being the list of Designer Locks. The locks are project resources that the designer session is using. Because that Designer session is using those project resources, no other Designers will be able to access those resources, to prevent two Designers from working on the same thing.
Session Details​
TimezoneLocal time of the user.
Designer Locks​
IdEach locked resource has its own unique Id number.
TypeResource Type.
NameName of the resource.
Connections Designer Details Page
