system.tag.editAlarmConfig
Edit the alarm configuration of multiple existing tags in Ignition with a single call.
Permission Type: Tag Editing
system.tag.editAlarmConfig(tagPaths, alarmConfig)
String[]tagPathsThe full path to the tag you want to edit.
Note: You can specify the tag provider name in square brackets at the beginning of the parentPath string. For example, [myTagProvider]MyTagsFolder. If the tag provider name is left off then the project default provider will be used.
PyDictionaryalarmConfigA dictionary of multi-dimensional lists containing the new alarm configuration. The key in the dictionary will be the name of the alarm being to edit, and the value is a list of lists. The nested lists use the format ["name", "Value", "newValue"].
Note: Item 1 is always "Value". For example, {"targetAlarm":[["propertyToChange","Value","newValue"],["anotherProperty","Value","anotherNewValue"]]}. If the name of the alarm does not match a pre-existing alarm, a new alarm will be created. Note that alarm names are case sensitive. Beware of typos.
A list of scripting names for each alarm property can be found on the Tag Properties page.
Nothing
All
Example #1 - Single Tag, Multiple Properties
# The following example will alter the alarm configuration on a single tag.
# The tag currently has an alarm named "High Temp". The code below will change the name of the alarm
# to "Low Temp", and change the Setpoint to 100.
# Build a list of tag paths. Only a single tag will be altered, so create a list of one item and store the list in a variable
tagPaths = ["sensors/B3:0"]
# Build the dictionary of alarm names, and properties to change.
alarmConfig = {"High Temp":[["name","Value","Low Temp"],["setpointA","Value","100"]]}
# Edit the alarm configuration.
Example #2 - Multiple Tags, Single Alarm per Tag
# The following example will disable alarms on multiple tags.
# The tags below both have an alarm named "Alarm"
#This code will edit the Enabled property for both alarms.
tagPaths = ["Tanks/Tank_1/level_PV", "Tanks/Tank_2/level_PV"]
# Build a dictionary of alarms. Both alarms have the name "Alarm", so a dictionary of one item
# will be able to alter both alarms in a single call.
alarmConfig = {"Alarm":[["enabled","Value","0"]]}
Example #3 - Multiple Tags, Multiple Alarms per Tag
# The following example will create two alarms each on two different tags.
# The code assumes there are not pre-existing alarms on the tags by the name of "High Level" and "Low Level"
# The Name, Mode, and Setpoint properties will be modified for each alarm.
tagPaths = ["Tanks/Tank_1/level_PV","Tanks/Tank_2/level_PV"]
# Configure two alarms on the tags.
# Mode value of 2 = Above Setpoint
# Mode value of 3 = Below Setpoint
alarmConfig = {"High Level":[["mode","Value","2"],["setpointA","Value",80]], "Low Level":[["mode","Value","3"],["setpointA","Value",15]]}
