system.tag.queryTagDensity
Queries the Tag history system for information about the density of data. In other words, how much data is available for a given time span.
This function is called with a list of Tag paths, and a start and end date. The result set is a two column dataset specifying the timestamp, and a relative weight. Each row is valid from the given time until the next row. Tags are assigned a 1 or a 0 if they are present or not. All values are then multiplied together to get a decimal based percentage for the density. Thus, for four Tag paths passed in, if three Tags were present during the span, the result would be 0.75.
system.tag.queryTagDensity(paths, startDate, endDate)
PySequencepathsAn array of Tag paths (strings) to query.
DatestartDateThe start of the range to query.
DateendDateThe end of the range to query.
Dataset - A 2-column dataset consisting of a timestamp and a weight. Each row is valid until the next row.
All
Example #1
# Will grab the density of a tag and print it out to the console.
density = system.tag.queryTagDensity(
['[default]myTag'],
system.date.addHours(system.date.now(), -24),
system.date.now())
density = system.dataset.toPyDataSet(density)
for row in density:
print row[0], row[1]
Example #2
# Create a list of times going back in time at day increments.
# This forces density readouts at each day, even if two days had the same density
now = system.date.now()
times = [system.date.addDays(now, -1), system.date.addDays(now, -2), system.date.addDays(now, -3), system.date.addDays(now, -4), system.date.addDays(now, -5), system.date.addDays(now, -6)]
# Create start and end date variables, as well as a variable that holds each history density.
startDate = now
endDate = now
list = []
# Loop through the list of times
for time in times:
# Set the new end date to whatever the start date was previously
# and the new start date to the next time in the list.
endDate = startDate
startDate = time
# Query Tag Density using a list of Tagpaths with the startDate and endDate values.
['[default]tag1', '[default]tag2', '[default]tag3', '[default]tag4', '[default]tag5'],
startDate, endDate)
# Add each row of the returned dataset to a list of rows.
for row in density:
list.append([row[0], row[1]])
# Place the results in a table.
event.source.parent.getComponent('Table').data = system.dataset.toDataSet(['Times', 'Density Percentages'], list)
Example #3
# This forces density readouts at each day, even if two days had the same density.
# This differs from the previous example in that it uses the new system.dataset.appendDataset function, which is only available in 7.9.7.
# Create start and end date variables.
startDate = now
endDate = now
# Loop through the list of times.
for time in times:
endDate = startDate
startDate = time
['[default]EquipmentFour', '[default]Ramp/Ramp6', '[default]Ramp/Ramp7', '[default]Ramp/Ramp8', '[default]Ramp/Ramp9'],
startDate, endDate)
if endDate == now:
densities = density
else:
densities = system.dataset.appendDataset(densities, density)
event.source.parent.getComponent('Table').data = densities
