system.tag.scan
Forces execution of a scan class. On a leased scan class, if both the fast and slow rate are set to 0, this will not execute.
system.tag.scan(provider, scname)
StringproviderThe name of the scan class provider. If blank, it will use the default. Required if used in the gateway scope.
StringscnameThe name of the scan class to execute.
Nothing
All
Example #1
# This code would immediately execute a scan on the scan class named My Slow Scan Class, even though it is only supposed to execute every minute.
system.tag.scan("MyProvider", "My Slow Scan Class")
