system.tag.removeTags
Removes multiple tags from Ignition with a single call.
Permission Type: Tag Editing
system.tag.removeTags(tagPaths)
String[]tagPathsAn array of the paths to the tags you want to remove.
Note: You can specify the tag provider name in square brackets at the beginning of the parentPath string. Example: [myTagProvider]MyTagsFolder. If the tag provider name is left off then the project default provider will be used. An empty path ( '' ) will remove all tags.
Nothing
All
Example #1
system.tag.removeTags(["Tag1", "Tag2"])
