system.tag.write
Writes a value to a tag. Note that this function writes asynchronously. This means that the function does not wait for the write to occur before returning - the write occurs sometime later on a different thread.
system.tag.write(tagPath, value, suppressErrors)
StringtagPathThe path of the tag to write to.
ObjectvalueThe value to write.
BooleansuppressErrorsA flag indicating whether or not to suppress errors. (optional, client-only).
int - 0 if the write failed immediately, 1 if it succeeded immediately, and 2 if it is pending.
All
Example #1
# This code would go on a property change event for a numeric text field to calculate and write a value to a tag.
if event.propertyName == intValue:
calcValue = event.newValue * 2.5
system.tag.write("Tanks/tankHiSP",calcValue)
