system.tag.loadFromFile
This function locates an exported tag file and loads the tags into the specified tag provider.
Permission Type: Tag Editing
system.tag.loadFromFile(filePath, provider, mode)
StringfilePathThe path of the tag file to import from.
StringproviderThe name of the provider to import to.
IntegermodeDictates what happens if the tag already exists. 0 = overwrite, 1 = ignore.
Nothing
All
Example #1
# The following example loads a file named 'tags.xml' located at C:\
# The backslash character is an escape character in python, so we have to use it twice for the filePath variable
# Create variables to pass into the function
filePath = 'C:\\tags.xml'
provider = 'default'
# Load the file
system.tag.loadFromFile(filePath,provider,0)
