system.tag.removeTag
Removes a tag from Ignition.
Permission Type: Tag Editing
system.tag.removeTag(tagPath)
StringtagPathThe path to the tag you want to remove.
Note: You can specify the tag provider name in square brackets at the beginning of the parentPath string. Example: [myTagProvider]MyTagsFolder. If the tag provider name is left off then the project default provider will be used. An empty path ( '' ) will remove all tags.
Nothing
All
Example #1
system.tag.removeTag("Tag1")
