--- title: "system.tag.removeTag" description: "Removes a tag from Ignition." --- # system.tag.removeTag > Removes a tag from Ignition. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Tag Editing Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.tag.removeTag(tagPath)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `tagPath` | The path to the tag you want to remove. **Note**: You can specify the tag provider name in square brackets at the beginning of the parentPath string. Example: `[myTagProvider]MyTagsFolder`. If the tag provider name is left off then the project default provider will be used. An empty path ( '' ) will remove all tags. | ### Returns Nothing ### Scope All ## Code Examples ```python title="Example #1" system.tag.removeTag("Tag1") ```
