--- title: "system.tag.editAlarmConfig" description: "Edit the alarm configuration of multiple existing tags in Ignition with a single call." --- # system.tag.editAlarmConfig > Edit the alarm configuration of multiple existing tags in Ignition with a single call. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Tag Editing Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.tag.editAlarmConfig(tagPaths, alarmConfig)` ### Parameters | Type | Parameter | Description | |---|---|---| | String[] | `tagPaths` | The full path to the tag you want to edit. **Note**: You can specify the tag provider name in square brackets at the beginning of the parentPath string. For example, `[myTagProvider]MyTagsFolder`. If the tag provider name is left off then the project default provider will be used. | | PyDictionary | `alarmConfig` | A dictionary of multi-dimensional lists containing the new alarm configuration. The key in the dictionary will be the name of the alarm being to edit, and the value is a list of lists. The nested lists use the format ["name", "Value", "newValue"]. **Note**: Item 1 is always "Value". For example, `{"targetAlarm":[["propertyToChange","Value","newValue"],["anotherProperty","Value","anotherNewValue"]]}`. If the name of the alarm does not match a pre-existing alarm, **a new alarm will be created**. Note that alarm names are case sensitive. Beware of typos. | A list of scripting names for each alarm property can be found on the [Tag Properties](tags\understanding-tags\tag-properties.md) page. ### Returns Nothing ### Scope All ## Code Examples ```python title="Example #1 - Single Tag, Multiple Properties" # The following example will alter the alarm configuration on a single tag. # The tag currently has an alarm named "High Temp". The code below will change the name of the alarm # to "Low Temp", and change the Setpoint to 100. # Build a list of tag paths. Only a single tag will be altered, so create a list of one item and store the list in a variable tagPaths = ["sensors/B3:0"] # Build the dictionary of alarm names, and properties to change. alarmConfig = {"High Temp":[["name","Value","Low Temp"],["setpointA","Value","100"]]} # Edit the alarm configuration. system.tag.editAlarmConfig(tagPaths, alarmConfig) ``` ```python title="Example #2 - Multiple Tags, Single Alarm per Tag" # The following example will disable alarms on multiple tags. # The tags below both have an alarm named "Alarm" #This code will edit the Enabled property for both alarms. # Build a list of tag paths. tagPaths = ["Tanks/Tank_1/level_PV", "Tanks/Tank_2/level_PV"] # Build a dictionary of alarms. Both alarms have the name "Alarm", so a dictionary of one item # will be able to alter both alarms in a single call. alarmConfig = {"Alarm":[["enabled","Value","0"]]} # Edit the alarm configuration. system.tag.editAlarmConfig(tagPaths, alarmConfig) ``` ```python title="Example #3 - Multiple Tags, Multiple Alarms per Tag" # The following example will create two alarms each on two different tags. # The code assumes there are not pre-existing alarms on the tags by the name of "High Level" and "Low Level" # The Name, Mode, and Setpoint properties will be modified for each alarm. # Build a list of tag paths. tagPaths = ["Tanks/Tank_1/level_PV","Tanks/Tank_2/level_PV"] # Configure two alarms on the tags. # Mode value of 2 = Above Setpoint # Mode value of 3 = Below Setpoint alarmConfig = {"High Level":[["mode","Value","2"],["setpointA","Value",80]], "Low Level":[["mode","Value","3"],["setpointA","Value",15]]} # Edit the alarm configuration. system.tag.editAlarmConfig(tagPaths, alarmConfig) ```
