system.user.editHoliday
Allows a holiday to be edited.
Permission Type: User Management
system.user.editHoliday(holidayName, holiday)
StringholidayNameThe name of the holiday to edit. Name is case-sensitive.
HolidayModelholidayThe edited holiday.
UIResponse - an object with lists of warnings, errors, and info about the success or failure of the edit.
Gateway, Designer, Client
Example #1
# This example gets a holiday and edits it
# This function prints the response received
def printResponse(responseList):
if len(responseList) > 0:
for response in responseList:
print "", response
else:
print " None"
# The main function
holidayName = "Labor Day"
myHoliday = system.user.getHoliday(holidayName)
if myHoliday != None:
myHoliday.setRepeatAnnually(False)
response = system.user.editHoliday(holidayName, myHoliday)
warnings = response.getWarns()
print "Warnings are:"
printResponse(warnings)
errors = response.getErrors()
print "Errors are:"
printResponse(errors)
infos = response.getInfos()
print "Infos are:"
printResponse(infos)
Example #1 Output
Warnings are:
None
Errors are:
None
Infos are:
Holiday "Labor Day" updated.
