system.user.removeSchedule
Allows a schedule to be deleted. Note that schedules which are used in Composite Schedules can not be deleted until they are removed from the Composite Schedule.
Permission Type: User Management
system.user.removeSchedule(scheduleName)
StringscheduleNameThe name of the schedule to delete. Name is case-sensitive.
UIResponse - An object with lists of warnings, errors, and info about the success or failure of the deletion.
Gateway, Designer, Client
Example #1
# This example tries to delete the schedule MySchedule, and prints the results of the action.
def printResponse(responseList):
if len(responseList) > 0:
for response in responseList:
print "", response
else:
print " None"
scheduleName = "MySchedule"
response = system.user.removeSchedule(scheduleName)
warnings = response.getWarns()
print "Warnings are:"
printResponse(warnings)
errors = response.getErrors()
print "Errors are:"
printResponse(errors)
infos = response.getInfos()
print "Infos are:"
printResponse(infos)
Example #1 Output
Warnings are:
None
Errors are:
None
Infos are:
Schedule "MySchedule" deleted.
