system.user.getSchedule
Returns a specific schedule.
system.user.getSchedule(scheduleNames)
StringscheduleNameThe name of the schedule to return. Case-sensitive
AbstractScheduleModel - The schedule, which can be a BasicSchedule, CompositeSchedule, or another type registered by a module, or None if not found.
Once the schedule is returned, functions of the resulting object are used to get various information from that schedule. Which functions are available depend on the type of schedule returned. See examples in the SDK documentation for an abstract schedule, basic schedule, or composite schedule.
Gateway, Designer, Client
Example #1
# This example will get a schedule and print info about it:
# This function handles recursive printing of the different schedule types. Modules can register more types than listed here.
def printScheduleInfo(aSchedule):
if aSchedule.getType() == "basic schedule":
print "Basic schedule type: ",aSchedule.getName(), aSchedule.getDescription(), aSchedule.isAllDays(), aSchedule.isObserveHolidays()
elif aSchedule.getType() == "composite schedule":
compositePieces = aSchedule.getModels()
print "Composite schedule type:",aSchedule.getName(), aSchedule.getDescription(), " which is made up of..."
for piece in compositePieces:
printScheduleInfo(piece)
else:
print "Other schedule type: ", aSchedule.getName(), aSchedule.getDescription(), aSchedule.getType(), aSchedule.isObserveHolidays()
# The main function
scheduleName = "MySchedule"
schedule = system.user.getSchedule(scheduleName)
if schedule == None:
print "Schedule", scheduleName, "was not found"
else:
printScheduleInfo(schedule)
Example #1 Output
Basic schedule type: MySchedule A description False True
