system.user.editSchedule
Allows a schedule to be edited.
Permission Type: User Management
system.user.editSchedule(scheduleName, schedule)
StringscheduleNameThe name of the schedule to edit. Name is case-sensitive.
AbstractScheduleModelscheduleThe edited schedule.
UIResponse - an object with lists of warnings, errors, and info about the success or failure of the edit.
Gateway, Designer, Client
Example #1
# This example tries to edit the schedule MySchedule, and prints the results of the action.
# This function prints the response received
def printResponse(responseList):
if len(responseList) > 0:
for response in responseList:
print "", response
else:
print " None"
# The main function
oldScheduleName = "MySchedule"
mySchedule = system.user.getSchedule(oldScheduleName)
if mySchedule != None and mySchedule.getType() == "basic schedule":
mySchedule.setObserveHolidays(False)
mySchedule.setName("MyEditedSchedule")
mySchedule.setDescription("A modified description")
response = system.user.editSchedule(oldScheduleName, mySchedule)
warnings = response.getWarns()
print "Warnings are:"
printResponse(warnings)
errors = response.getErrors()
print "Errors are:"
printResponse(errors)
infos = response.getInfos()
print "Infos are:"
printResponse(infos)
else:
print "Basic schedule", oldScheduleName, "not found."
Example #1 Output
Warnings are:
None
Errors are:
None
Infos are:
Schedule "MyEditedSchedule" updated.
