system.user.addSchedule
Adds a schedule.
Permission Type: User Management
system.user.addSchedule(schedule)
AbstractScheduleModelscheduleThe schedule to add.
UIResponse - an object with lists of warnings, errors, and info about the success or failure of the add.
Gateway, Designer, Client
Example #1
# This example tries to add the schedule NewSchedule based on an existing schedule MySchedule, and prints the results of the action.
# This function prints the response received
def printResponse(responseList):
if len(responseList) > 0:
for response in responseList:
print "", response
else:
print " None"
# The main function
mySchedule = system.user.getSchedule("Always")
if mySchedule != None and mySchedule.getType() == "basic schedule":
mySchedule.setObserveHolidays(False)
mySchedule.setName("NewSchedule")
response = system.user.addSchedule(mySchedule)
warnings = response.getWarns()
print "Warnings are:"
printResponse(warnings)
errors = response.getErrors()
print "Errors are:"
printResponse(errors)
infos = response.getInfos()
print "Infos are:"
printResponse(infos)
Example #1 Output
Warnings are:
None
Errors are:
None
Infos are:
New schedule "NewSchedule" added.
