system.user.addRole
Adds a role to the specified user source. When altering the Gateway System User Source, the Allow User Admin setting must be enabled.
Permission Type: User Management
system.user.addRole(userSource, role)
StringuserSourceThe user source to add a role to. Blank will use the default user source.
StringroleThe role to add. Role must not be blank and must not already exist.
UIResponse - an object with lists of warnings, errors, and info about the success or failure of the add.
Gateway, Designer, Client
Example #1
# This example adds a role "Operator" to the user source "MyUserSource".
system.user.addRole("MyUserSource", "Operator")
