system.user.removeRole
New in 7.9.5
Removes a role from the specified user source. When altering the Gateway System User Source, the Allow User Admin setting must be enabled.
Permission Type: User Management
system.user.removeRole(userSource, role)
StringuserSourceThe user source in which the role is found. Blank will use the default user source.
StringroleThe role to remove. The role must exist.
UIResponse - An object with lists of warnings, errors, and info about the success or failure of the deletion.
Gateway, Designer, Client
Example #1
# Removes the role "User" in the user source "MyUserSource".
system.user.removeRole("MyUserSource", "User")
