system.user.addSchedule
Descriptionβ
Adds a schedule.
Permission Type: User Management
Syntaxβ
system.user.addSchedule(schedule)
Parametersβ
| ScheduleModel | schedule | The schedule to add. Can be a BasicScheduleModel or CompositeScheduleModel object (or any other class that extends AbstractScheduleModel). |
Returnsβ
UIResponse - A UIResponse object with lists of warnings, errors, and info about the success or failure of the add. The contents of the lists are accessible from the getter methods.
getWarns()- Returns a list of warning messages that were encountered during the add.getErrors()- Returns a list of error messages that were encountered during the add.getInfos()- Returns a list of "info" messages that were encountered during the add.
These messages represent normal logging events that occurred during the add, and can be useful when trying to visualize the events that lead up to a failure.
Scopeβ
Code Examplesβ
Example #1
# This example tries to add the schedule NewSchedule based on an existing schedule MySchedule, and prints the results of the action.
# This function prints the response received.
def printResponse(responseList):
if len(responseList) > 0:
for response in responseList:
print "", response
else:
print " None"
# The main function.
mySchedule = system.user.getSchedule("Always")
if mySchedule != None and mySchedule.getType() == "basic schedule":
mySchedule.setObserveHolidays(False)
mySchedule.setName("NewSchedule")
response = system.user.addSchedule(mySchedule)
warnings = response.getWarns()
print "Warnings are:"
printResponse(warnings)
errors = response.getErrors()
print "Errors are:"
printResponse(errors)
infos = response.getInfos()
print "Infos are:"
printResponse(infos)
"""The example above outputs the following:
Warnings are:
None
Errors are:
None
Infos are:
New schedule "NewSchedule" added.
