Version: 8.1
system.user.editRole
Renames a role in the specified user source. When altering the Gateway System User Source, the Allow User Admin setting must be enabled.
Permission Type: User Management
system.user.editRole(userSource, oldName, newName)
StringuserSourceThe user source in which the role is found. Blank will use the default user source.
StringoldNameThe role to edit. Role must not be blank and must exist.
StringnewNameThe new name for the role. Must not be blank.
UIResponse - A UIResponse object with lists of warnings, errors, and info about the success or failure of the edit.
Example #1
# This example edits the role "Operator" in the user source "MyUserSource" and edits it to the role "User".
system.user.editRole("MyUserSource", "Operator", "User")
