Version: 8.1
system.user.addCompositeSchedule
Allows two schedules to be combined into a composite schedule.
Permission Type: User Management
system.user.addCompositeSchedule(name, scheduleOne, scheduleTwo, [description])
StringnameThe name of the new composite schedule.
StringscheduleOneThe first schedule to combine.
StringscheduleTwoThe second schedule to combine.
StringdescriptionDescription of the new combined schedule. [optional]
UIResponse - A UIResponse object with lists of warnings, errors, and info about the success or failure of the add. The contents of the lists are accessible from the getter methods.
  • getWarns() - Returns a list of warning messages that were encountered during the add.
  • getErrors() - Returns a list of error messages that were encountered during the add.
  • getInfos() - Returns a list of "info" messages that were encountered during the add.
These messages represent normal logging events that occurred during the add, and can be useful when trying to visualize the events that lead up to a failure.
Example #1
# Assuming you already have two schedules configured, named "A Shift" and "B Shift",
# you could create a composite schedule with the following.
def printResponse(responseList):
if len(responseList) > 0:
for response in responseList:
print "", response
else:
print " None"
response = system.user.addCompositeSchedule("A and B Shift", "A Shift", "B Shift", "Both A and B combined")
warnings = response.getWarns()
print "Warnings are:"
printResponse(warnings)
errors = response.getErrors()
print "Errors are:"
printResponse(errors)
infos = response.getInfos()
print "Infos are:"
printResponse(infos)
"""The example above outputs the following:
Warnings are:
None
Errors are:
None
Infos are:
New schedule "A and B Shift" added.
