system.user.editUser
Alters a specific user in a user source, replacing the previous data with the new data passed in.
Permission Type: User Management
system.user.editUser(userSource, user)
Type | Parameter | Description |
String | userSource | The user source in which the user is found. Blank will use the default user source. |
User | user | The user to update, as a User object. Refer also to the PyUser class. |
A UIResponse object with lists of warnings, errors, and information returned after the edit attempt.
Example #1
# Retrieve the user we're going to edit.
userToChange = system.user.getUser("default", "george")
# Make a change to the user. In this case, we're adding some contact info.
contactInfo = {"email":"ignition_user@mycompany.com","sms": "5551212"}
userToChange.addContactInfo(contactInfo)
# Edit the user. Because the user object we're passing in has a user name, the function
# already knows which user to edit.
system.user.editUser("default", userToChange)
