system.user.editRole
Descriptionβ
Renames a role in the specified user source. When altering the Gateway System User Source, the Allow User Admin setting must be enabled.
Permission Type: User Management
Syntaxβ
system.user.editRole(userSource, oldName, newName)
Parametersβ
| String | userSource | The user source in which the role is found. Blank will use the default user source. |
| String | oldName | The role to edit. Role must not be blank and must exist. |
| String | newName | The new name for the role. Must not be blank. |
Returnsβ
UIResponse - A UIResponse object with lists of warnings, errors, and info about the success or failure of the edit. The contents of the lists are accessible from the getter methods.
getWarns()- Returns a list of warning messages that were encountered during the edit.getErrors()- Returns a list of error messages that were encountered during the edit.getInfos()- Returns a list of "info" messages that were encountered during the edit.
These messages represent normal logging events that occurred during the edit, and can be useful when trying to visualize the events that lead up to a failure.
Scopeβ
Code Examplesβ
# This example edits the role "Operator" in the user source "MyUserSource" and edits it to the role "User".
system.user.editRole("MyUserSource", "Operator", "User")
