system.user.editHoliday
Descriptionβ
Allows a holiday to be edited.
Permission Type: User Management
Syntaxβ
system.user.editHoliday(holidayName, holiday)
Parametersβ
| String | holidayName | The name of the holiday to edit. Name is case-sensitive. |
| HolidayModel | holiday | The edited holiday, as a HolidayModel object. |
Returnsβ
UIResponse - A UIResponse object with lists of warnings, errors, and info about the success or failure of the edit. The contents of the lists are accessible from the getter methods.
getWarns()- Returns a list of warning messages that were encountered during the edit.getErrors()- Returns a list of error messages that were encountered during the edit.getInfos()- Returns a list of "info" messages that were encountered during the edit.
These messages represent normal logging events that occurred during the edit, and can be useful when trying to visualize the events that lead up to a failure.
Scopeβ
Code Examplesβ
Example #1
# This example gets a holiday and edits it.
# This function prints the response received.
def printResponse(responseList):
if len(responseList) > 0:
for response in responseList:
print "", response
else:
print " None"
# The main function.
holidayName = "Labor Day"
myHoliday = system.user.getHoliday(holidayName)
if myHoliday != None:
myHoliday.setRepeatAnnually(False)
response = system.user.editHoliday(holidayName, myHoliday)
warnings = response.getWarns()
print "Warnings are:"
printResponse(warnings)
errors = response.getErrors()
print "Errors are:"
printResponse(errors)
infos = response.getInfos()
print "Infos are:"
printResponse(infos)
"""The example above outputs the following:
Warnings are:
None
Errors are:
None
Infos are:
Holiday "Labor Day" updated.
