Version: 8.3
Tag Providers
At the highest level of tag configuration is the Tag Provider. A provider is a tag database (a collection of tags) and a name. An Ignition Gateway can have any number of Tag Providers, and therefore the name is used to distinguish which provider a tag comes from. Tag Providers can be set up with security or even disabled independent of each other.
Every copy of Ignition has its own tags, spread across one or more Tag Providers. With the Remote Tag Provider, Ignition can also see the tags on another Gateway, as long as the two Gateways are connected through a Gateway network.
All tags reside in a Tag Provider and have realtime values. Additionally, there is the concept of Tag Historian Providers, which can store and query historical data for tags. Each tag can optionally have a historian provider assigned to it to whom it will report value changes for historical storage.
Realtime Provider Types​
Inductive University
Tag Providers
Watch the video
There are two types of Realtime Tag Providers that you can choose from:
Standard Tag Provider​
Standard Tag Providers store all configuration and do any execution (read, write, history, alarms) through the local Ignition Gateway. Every new Ignition installation automatically creates a Standard Tag Provider named default. You can add as many Standard Tag Providers as you want. This provider can be exposed or hidden from other Gateways on the network through the Gateway's OPC UA settings.
Remote Tag Provider​
Remote Tag Provider
Watch the video
Remote Tag Providers connect a remote installation of Ignition and access those tags. The Remote Tag Provider works by creating a link from the local Gateway to a Tag Provider on a remote Gateway using a Gateway Network connection. The local Ignition may be allowed to read and write to the remote tags, but any execution is handled by the remote Gateway. So, things like writing to a PLC, alarms, and history will still be handled by the remote Ignition.
Put another way, "tags" in a Remote Tag Provider are simply representations of the tags as they exist on the remote system. By default, a Remote Tag Provider will fall under the Default Security Zone and be read only.
note
Annotations to remote Gateways via Remote Tag Providers are not supported. If you want to send annotations to a remote Gateway, you can instead use a Remote Historian provider.
Managed Tag Provider​
Every Gateway also includes a System Tag Provider, which is configured as a Managed type. The System Tag Provider stores Client and Gateway tags that provide status about the Ignition system. Additional Managed Tag Providers cannot be created by users, and the System Tag Provider cannot be deleted or modified. The only option available to edit is enabling or disabling the Tag Reference Tracker Store.
Configuring Realtime Providers​
Realtime Tag Providers are configured in the Gateway's Services section under Tags. The Ignition Gateway will start with a System Tag Provider defined.
Gateway Services - Realtime Tags Location and Default Provider
You can edit a Tag Provider's name or settings by clicking on the three dots menu to the right and selecting Rename and Edit, or create new providers by selecting Create Tag Provider above the table.
Gateway Services - Realtime Tags Edit and Create
note
When setting up a Realtime Tag Provider, naming your Provider the same name as the database connection is not recommended. Doing so may cause no values to be returned when querying tag data.
Standard Tag Provider Settings​
Tags are stored inside of Ignition and executed by the system.
SettingDescription
NameThe name of the provider.
DescriptionThe description of the provider.
EnabledIf true, Tag Provider is enabled. Default is true.
Default DatasourceThe default database connection to use for Expression tags that run SQL queries. All Query tags with default database providers selected with run their queries against this database source.
Value PersistenceThe behavior for how Memory tag values will be stored. Possible values include:
  • None: Memory tag value changes will persist in the memory only and on Gateway restarts, the value will revert to the configuration value.
  • Database: Memory tag value changes will persist to a SQLite DB and be reloaded on start, but will not modify the configuration value when changed. Note that the configuration file will be modified with an edit to the tag, such as adding an alarm.
  • Configuration: Memory tag value changes will persist to the tag configuration. This option should be used sparingly to avoid performance hits.
Note: This setting can be overridden for individual Memory tags in the Tag Editor.
Tag Read PermissionsAny actor attempting to read any tag within this tag provider must have these permissions in addition to the target tag's permissions. Multiple security level paths can be specified by separating them with commas. If blank, tag reads for this provider will not be restricted by default. For example:
Authenticated/Roles/Administrator, SecurityZones/MyZone
When multiple security levels are provided, the radio buttons determine if the user needs all of the listed security levels, or at least one.
Read OnlyIf enabled, writes to any tag within this Tag Provider will be rejected, regardless of the target tag's permissions. Disabled by default.
Tag Write PermissionsAny actor attempting to write to any tag within this Tag Provider must have these permissions in addition to the target tag's permissions. Multiple security level paths can be specified by separating them with commas. If blank, tag writes for this provider will not be restricted by default.
See the example for the Tag Read Permissions setting above.
Tag Editing PermissionsDetermines the roles required to edit, create, or delete tags in the provider. Expects a path to a Security Level. Multiple levels can be specified, separated by a comma. For example:
Edge Gateways can access the Tag Editing Permissions setting.
Allow Back-fill DataIf enabled, data will be allowed to arrive out of order from the source. Data from the past will be stored to history, but will not be used for alarms, scripts, or subscriptions. If false (default behavior), each value will be processed fully as it arrives. Default is false.
Enable Tag Reference Tracker StoreEnables the storing of Tag Reference entries to a database on the local Gateway for analysis in a Designer. Default is true.
Remote Tag Provider Settings​
Tag Provider from one Gateway is brought in to another Gateway.
SettingDescription
EnabledIf true, the Remote Tag Provider is enabled. Default is true.
GatewayThe name of the Gateway on the Gateway Network that this provider is coming from.
ProviderThe name of the provider as it is on the remote Gateway. This does not have to be the same as its name on the new Gateway.
History Access ModeThis setting dictates how Tag history is queried for remote tags. Ultimately determines where records are processed.
When set to GatewayNetwork, history requests will go through the Gateway Network. Meaning the remote Gateway will query records from it's database, process the records, then send the results over to the requesting Gateway.
When set to Database history requests will run against the database directly. In this scenario, the requesting Gateway then processes the data.
History DatasourceThe data source to query when History Access Mode is set to Database.
History DriverIf querying the database directly, this is the Gateway name of the remote system. It is used to identify data from that system in the database.
History ProviderIf querying the database directly, this is the name of the Tag Provider on the remote system. It is used along with driver name to identify the correct tags in the database.
Alarms EnabledIf true, alarms configured on the remote Gateway will be enabled on the new Gateway.
Alarm ModeHow alarm states should be monitored. Options include:
  • Queried: The alarm state will be queried through the Gateway network when necessary.
  • Subscribed: The alarm state will be subscribed, and updates will be sent asynchronously. Subscribed provides better performance, but uses more memory.
