Version: 8.3 Beta 🚧
System Tags
Inductive University
System Tags
Watch the video
System tags provide status about the Ignition system, such as memory usage, performance metrics, and so on. System tags cannot be deleted or modified. To view the System tags in the Tag Browser, go to the Tag Provider Selector and select System.
The System tags folders are displayed: Client and Gateway. The scope for each is slightly different.
System Client Tags (Vision Only)​
Client-scoped System tags provide status information about the client's system. They can be used with the Vision module for any Vision Client. Every individual client is going to have their own values, such as IP address, host name, username, and more. There are three folders within the System > Client folder: Network, System, and User. You cannot modify Client System tags.
Vision System Client Tags​
NameFolderDescriptionData Type
GatewayAddressNetworkGateway URL address.string
GatewayRedundancyRoleNetworkRedundancy State of the Gateway that the client is connected to. Independent, Master, Backup.string
HostnameNetworkHostname (name) of the computer that the Client is running on.string
IPAddressNetworkIP Address of the computer that the Client is running on.string
MACAddressNetworkMAC Address of the computer that the Client is running on.string
CurrentDateTimeSystemCurrent system date and time. Format is yyyy-MM-dd hh:mm:ss a.DateTime
DefaultDatabaseSystemName of the default database connection used by the project.string
DefaultTagProviderSystemName of the default Tag Provider used by the project.string
FPMIVersionSystemCurrent Ignition version in use.string
JavaVersionSystemCurrent Java version in use by the client.string
LastProjectUpdateSystemDate and time the local Vision Client’s project was last updated.DateTime
OperatingSystemSystemOperating system of the computer that the Client is running on.string
ProjectNameSystemName field for the current project.string
ProjectTitleSystemTitle field for the current project.string
ProjectUpdateAvailableSystemWhether or not there is a project update available for the currently open Vision Client project. Intended to be used alongside the None option in Vision's Project Properties.boolean
SystemFlagsSystemA byte array of flags for the current state of the Client.integer
UserSourceSystemName of the user source for the current Client.string
CountryUserTwo letter country code according to operating system. for example: US.string
CurrentWindowUserThe current main window open in the project (top most Floating, Maximized window).string
DateFormatFullUserFull date format according to the operating system. Format: EEEE, MMMM d, y.string
DateFormatLongUserLong date format: MMMM d, y.string
DateFormatMediumUserMedium date format: MMM d, y.string
DateFormatShortUserShort date format: M/d/yy.string
DateTimeFormatFullUserFull date and time format: EEEE, MMMM d, y 'at' h:mm:ss a zzzz.string
DateTimeFormatLongUserLong date and time format: MMMM d, y 'at' h:mm:ss a.string
DateTimeFormatMediumUserMedium date and time format: MMM d, y, h:mm:ss a zzzz.string
DateTimeFormatShortUserShort date and time format: M/d/y, h:mm a.string
HomeFolderUserHome folder according to OS. For example: C:\Users\psmith.string
LanguageUserLanguage according to OS. For example: "en" for English.string
OSUsernameUserOS user name, for example: PSmith.string
RolesDataSetUserDataset with Roles for currently logged in user. For example: Dataset[2R x 1C].dataset
RolesStringUserComma separated string with Roles for currently logged in user. For example: Administrator, Operator.string
TimeFormatFullUserFull time format according to the operating system. Format: h:mm:ss a zzzz.string
TimeFormatLongUserLong time format: h:mm:ss a z.string
TimeFormatMediumUserMedium time format: h:mm:ss a.string
TimeFormatShortUserSort time format: h:mm a.string
TimezoneUserCurrent timezone, for example, America/Los Angeles.string
UsernameUserCurrently logged in username, for example, PSmith.string
Gateway System Tags​
Gateway System tags exist in the Gateway scope. There are several folders within the Gateway tags folder which report metrics on various Gateway level systems.
The following Gateway-scoped System tags are available.
Root System Tags​
NameDescriptionData Type
CurrentDateTimeCurrent system date and time. Format is yyyy-mm-dd hh:mm:ss a.DateTime
LicenseStateReturns the license state of the Gateway. If a valid license is applied, the tag will return "Activated". This includes Emergency Activation mode and Maker licensing. For any other license state, the tag will return "Trial".String
SystemNameReturns the name of the system where the Ignition Gateway is installed.String
TimezoneTimezone on the Gateway computer. For example, America/Los Angeles.String
UptimeSecondsNumber of seconds since Ignition was started.Long
Alarming System Tags​
Active and AckedNumber of alarms currently active and acknowledged.Integer
Active and UnackedNumber of alarms currently active and unacknowledged.Integer
Clear and AckedNumber of alarms cleared and acknowledged.Integer
Clear and UnackedNumber of alarms cleared and unacknowledged.Integer
Database System Tags​
note
There will be a subfolder for each database connection, or none if there are no connections. Each subfolder will have the following Tags.
ActiveConnectionsNumber of active connections in the pool to this database connection.Integer
AvailableIndicates whether this datasource is available.Boolean
AvailableThroughFailoverIndicates if any database along the failover chain attached to this data source can be reached.Boolean
AvgQueryTimeAverage time, in seconds, that it is taking database queries to run.Integer
ConnectionSaturationPercentage of possible query throughput that is being used (ratio of currently active connections to maximum possible connections).Double
QueriesPerSecondNumber of queries running per second.Integer
Device System Tags​
note
For each device configuration on the Gateway, a separate subfolder will exist. The contents of each subfolder are listed below.
DescriptionDescription of the device connection as configured on the device connection on the Gateway.String
EnabledBoolean representing whether or not the device connection is enabled.Boolean
NameName of the device connection.String
StatusStatus of the connection.String
EAM System Tags​
note
System tags are created on the Controller for each agent, allowing you to build EAM monitoring clients, set alarms on individual tags, and many other tag-related operations. A folder is created for each agent. As with other System tag values, all EAM system tag values are read-only.
Metrics Folder​
The metric folder contains multiple subfolders.
Database Folder Each database connection on the agent will be represented by a different folder.
Active ConnectionsNumber of active connections in the pool to this database connection.Integer
Active QueriesNumber of active queries.Integer
Active Query DurationAverage time, in seconds, that it is taking database queries to run.Integer
Average Throughput Per SecondNumber of records forwarded to the data sink per second. Throughput will be -1 if idle.Integer
Logging Folder
Errors Per HourNumber of errors logged per hour.Integer
Errors Per MinuteNumber of errors logged per minute.Integer
Session Folder
ClientsNumber of currently running Vision clients.Long
DesignersNumber of currently running Designers.Long
Perspective SessionsNumber of currently running Perspective sessions.Long
System Folder
CPU UsageCPU Utilization as reported to the Java Virtual Machine.Float
Memory UsageAmount of RAM currently in use by the Gateway, in whole percentages from 0-100.Float
Module Versions Folder​
The ModuleVersions folder contains tags for each module installed on the agent where the tag name reflects the module name and the tag value displays the module version number.
Root Tags​
The following tags are located in the root of the EAM folder
AgentGroupName of the group that the Agent belongs to.String
AgentNameName of the Agent.String
BrowserURLAgent Gateway URL address.String
IsApprovedWhether this network connection has been approved.Boolean
IsConnectedWhether the Gateway Network connection is active.Boolean
IsRunningWhether the Agent Gateway is considered "healthy". Healthy Agent Gateways may not be connected to the Controller, but not enough time has passed to consider the Agent Gateway as "down".Boolean
LastCommunicationA timestamp representing the last known communication received from the Gateway.DateTime
LicenseKeyReturns the license key of the Gateway.String
NodeRoleRole of the connected Agent.
  • Independent - Redundancy is not enabled and this Ignition system runs as an independent node.
  • Master - This is the Master node, who listens for a connection from the Backup node, and is in charge of managing system synchronization.
  • Backup - This is the Backup node, who will connect to the Master and receive system updates.
String
PlatformEditionIgnition Edition running on the Agent Gateway. Values include standard, edge, and maker.String
RunningStateString representation of the Running State. Possible values for RunningState are: Disconnected, Running, Warned, Er`roredString
RunningStateIntInteger representation of the Running State.Integer
ServerIdID of the Agent Gateway.String
VersionVersion of Ignition software running on the Agent Gateway.String
Gateway Network System Tags​
Each system connected over the Gateway Network receives a special folder designated by the following nomenclature:
  • Independent Gateways: 0:0
  • Redundant Master Gateway: 0:1
  • Redundant Backup Gateway: 0:2
  • "Virtual" route aliased to either the Master or Backup Gateways: 0:0
Each folder contains the following tags.
IsAvailableWhether the remote Gateway is available or not.Boolean
LastCommA timestamp representing the last known communication received from the remote Gateway.DateTime
Licenses System Tags​
This tag folder will only appear if your Gateway is using a Leased License. For each leased license on the Gateway, a separate subfolder will exist. The contents of each subfolder are listed below.
ConsecutiveErrorCountRolling counter for how many times the license tried to renew itself, if failed.Long
ErrorCodeDisplays an error code if the license failed to renew.Integer
ExpirationTime when the session expires.DateTime
ExpiresInSecondsAmount of time left before the current lease period expires, in seconds.Long
NextCheckTime when the license will attempt to renew.DateTime
ProblemDescription of why the license failed to renew or activate.String
StatusCurrent status of the leased license.String
OPC System Tags​
note
There will be a subfolder for each OPC UA Server. Each subfolder will have the following tags.
ConnectedWhether the OPC UA server is connected to Ignition.Boolean
EnabledWhether the OPC UA server connection is enabled.Boolean
StateThe state name of the connection. For example: Connected, Faulted, Connecting.String
Performance System Tags​
Available Disk Space (MB)Available disk space on the computer Ignition is installed on, in megabytes.Long
CPU UsageCPU Utilization as reported to the Java Virtual Machine.Double
Disk UtilizationPercentage of hard disk that is in use.Double
Max MemoryMaximum amount of RAM the Gateway can use, in bytes.Long
Memory UsageAmount of RAM currently in use by the Gateway, in bytes.Long
Memory UtilizationCurrent memory usage/maximum memory usage.Double
Redundancy System Tags​
Connection, Is ConnectedWhether this Gateway is connected to another for redundancy.Boolean
Connection, PeerIdThe ID of the Gateway connected to, empty string if not connected.String
ActivityLevelIndicates where the Gateway is in the redundant state. Can be undecided, cold, warm, or active.String
IsActiveWhether the Gateway is running.Boolean
IsMasterWhether the Gateway is the master. False if the backup is in control.Boolean
RoleNamed role of the Gateway. Options: Independent, Master, Backup.String
Sessions System Tags​
SessionCountNumber of active sessions on this Gateway. Note this value does not account for Perspective Client Sessions.Integer
Store and Forward System Tags​
Each database connection will have their own set of System Tags.
TotalDroppedCountThe total number of dropped datapoints within the Store and Forward engine.Integer
TotalPendingCountThe current total number of pending datapoints within the memory buffer and disk cache waiting to be pushed through the Store and Forward engine.Integer
TotalQuarantinedCountThe current total number of datapoints that are in quarantine.Integer
In addition to the tags above, each database connection contains multiple subfolders. The subfolders are listed as tables below.
ForwardMetric​
FifteenMinuteRateThe rate at which datapoints are forwarded to the database or remote Gateway at 15 minute intervals.Integer
FiveMinuteRateThe rate at which datapoints are forwarded to the database or remote Gateway at five minute intervals.Integer
OneMinuteRateThe rate at which datapoints are forwarded to the database or remote Gateway at one minute intervals.Integer
StoreMetric​
FifteenMinuteRateThe rate at which datapoints are stored to the Store and Forward engine at 15 minute intervals.Integer
FiveMinuteRateThe rate at which datapoints are stored to the Store and Forward engine at five minute intervals.Integer
OneMinuteRateThe rate at which datapoints are stored to the Store and Forward engine at one minute intervals.Integer
