system.dataset.toDataSet
This function is used to
  1. Convert PyDataSets to DataSets
  2. Create new datasets from raw Python lists. When creating a new dataset, headers should have unique names.
Syntax (Without Headers)​
system.dataset.toDataSet(dataset)
PyDataSetdatasetA PyDataSet object to convert.
Dataset - The newly created dataset.
All
Syntax (With Headers)​
system.dataset.toDataSet(headers, data)
PySequenceheadersA PyDataSet object to convert.
PySequencedataA list of rows for the new dataset. Each row must have the same length as the headers list, and each value in a column must be the same type.
All
Example 1
# This example create a single column dataset.
header = ['myColumn']
rows = [[1], [2]]
dataset = system.dataset.toDataSet(header, rows)
Example 2
# This first example shows how this function can be used to convert from a PyDataSet (which is what system.db.runQuery returns) to a normal DataSet, which is the datatype of a Table component's data property.
pyDataSet = system.db.runQuery("SELECT * FROM example1 LIMIT 100")
table = event.source.parent.getComponent("Table")
normalDataSet = system.dataset.toDataSet(pyDataSet)
table.data = normalDataSet
