system.dataset.sort
Sorts a dataset and returns the sorted dataset. This works on numeric, as well as alphanumeric columns. It will go character by character, going from 0-9, A-Z, a-z.
system.dataset.sort(dataset, keyColumn [, ascending])
DatasetdatasetThe dataset to sort.
intkeyColumnThe index or column name of the column to sort on.
booleanascendingTrue for ascending order, False for descending order. If omitted, ascending order will be used.[ optional ]
PyObjectvalueThe new value for the specified row/column.
Dataset - A new sorted dataset.
All
Example 1
# This code will take the data in a table component, sort it based on the column with index 1,
# and then reinsert the sorted data into the same table.
data = event.source.parent.getComponent('Table').data
newData = system.dataset.sort(data, 1)
event.source.parent.getComponent('Table').data = newData
Example 2
# This code will create a dataset in scripting, and then sort it based on the name of one of the columns.
# It then inserts the sorted dataset into a table component.
headers = ["City", "Population", "Timezone", "GMTOffset"]
data = []
data.append(["New York", 8363710, "EST", -5])
data.append(["Los Angeles", 3833995, "PST", -8])
data.append(["Chicago", 2853114, "CST", -6])
data.append(["Houston", 2242193, "CST", -6])
data.append(["Phoenix", 1567924, "MST", -7])
cities = system.dataset.toDataSet(headers, data)
newData = system.dataset.sort(cities, "City")
