system.dataset.filterColumns
Takes a dataset and returns a view of the dataset containing only the columns found within the given list of columns.
system.dataset.filterColumns(dataset, columns)
DatasetdatasetThe starting dataset.
PySequencecolumnsA list of columns to keep in the returned dataset. The columns may be in integer index form (starting at 0), or the name of the columns as Strings.
Dataset - A new dataset containing the filtered columns.
All
Example 1
# This example takes the dataset from a five column Bar Chart and displays a subset of the data in two separate tables. This is performed in a button component actionPerformed script.
chartData = event.source.parent.getComponent('Bar Chart').data
northSouth = [1, 2] # North Area, South Area cols
eastWest = ["East Area", "West Area"]
filteredData = system.dataset.filterColumns(chartData, northSouth)
event.source.parent.getComponent('NorthSouthTable').data = filteredData
filteredData = system.dataset.filterColumns(chartData, eastWest)
event.source.parent.getComponent('EastWestTable').data = filteredData
