system.dataset.clearDataset
Takes a dataset and returns a new dataset with all of the same column names, but all of the rows deleted.
system.dataset.clearDataset(dataset)
DatasetdatasetThe starting dataset. If NULL, a NULL dataset will be returned.
Dataset - A new dataset that is a combination of the original two datasets.
All
Example 1
# This example pulls in the dataset from a Table component, clears it, then writes the empty dataset back to the table.
data = event.source.parent.getComponent('Table').data
event.source.parent.getComponent('Table').data = system.dataset.clearDataset(data)
