system.dataset.exportExcel
Exports the contents of a dataset as an Excel spreadsheet, prompting the user to save the file to disk. Uses the same format as the dataSetToExcel function.
system.dataset.exportExcel(filename, showHeaders, dataset[, nullsEmpty])
StringfilenameA suggested filename to save as.
BooleanshowHeadersIf true (1), the spreadsheet will include a header row.
Object[]datasetA sequence of datasets, one for each sheet in the resulting workbook.
BooleannullsEmpty
New in 7.9.8
If True (1), the spreadsheet will leave cells with NULL values empty, instead of allowing Excel to provide a default value like 0. Defaults to False. [Optional]
String - The path to the saved file, or None if the action was canceled by the user.
Client
Example 1
# This snippet would prompt the user to save the data currently displayed in a Table component to an Excel-compatible spreadsheet file, and would open the file after a successful save.
table = event.source.parent.getComponent("Table")
filePath = system.dataset.exportExcel("data.xls", 1, table.data)
if filePath != None:
system.net.openURL("file://"+filePath)
