system.dataset.exportExcel
Descriptionβ
Exports the contents of a dataset as an Excel spreadsheet, prompting the user to save the file to disk. Uses the same format as the system.dataset.toExcel function. To write silently to a file, you cannot use the dataset.export* functions. Instead, use the toExcel() function.
Syntaxβ
system.dataset.exportExcel(filename, showHeaders, dataset, [nullsEmpty])
Parametersβ
| String | filename | A suggested filename to save as. |
| Boolean | showHeaders | If true, the spreadsheet will include a header row. |
| Dataset / List[Dataset] | dataset | Either a single dataset, or a list of datasets. When passing a list, each element represents a single sheet in the resulting workbook. |
| Boolean | nullsEmpty | If True, the spreadsheet will leave cells with NULL values empty, instead of allowing Excel to provide a default value like 0. Defaults to False. [optional] |
Returnsβ
String - The path to the saved file, or None if the action was canceled by the user.
Scopeβ
Vision Client
Code Examplesβ
Code Snippet
# This snippet prompts the user to save the data currently displayed in a Table component to an Excel-compatible spreadsheet file. It opens the file after a successful save.
table = event.source.parent.getComponent("Table")
filePath = system.dataset.exportExcel("data.xlsx", 1, table.data)
if filePath != None:
system.net.openURL("file://"+filePath)
