system.dataset.exportCSV
Exports the contents of a dataset as a CSV file, prompting the user to save the file to disk. To write silently to a file, you cannot use the dataset.export* functions. Instead, use the toCSV() function.
system.dataset.exportCSV(filename, showHeaders, dataset)
| String | filename | A suggested filename to save as. |
| Boolean | showHeaders | If true, the CSV file will include a header row. |
| Dataset | dataset | The dataset to export. |
String - The path to the saved file, or None if the action was canceled by the user.
Vision Client
Code Snippet
# This snippet would prompt the user to save the data currently displayed in a Table component to a CSV file, and would open the file (in an external program, presumably Excel) after a successful save.
table = event.source.parent.getComponent("Table")
filePath = system.dataset.exportCSV("data.csv", 1, table.data)
if filePath != None:
system.net.openURL("file:///"+filePath.replace('\\','/'))
