Equipment Schedule Scripting
Scripting Functions​
This component does not have scripting functions associated with it.
Extension Functions​
onBackgroundDragged​
  • Description
    • Called when the user drags a segment on the schedule background.
  • Parameters
    • Component self - A reference to the component that is invoking this function.
    • int itemID - The ID of the equipment item of the row where the user dragged.
    • Date startDate - The datetime corresponding to where the user started dragging.
    • Date endDate - The datetime corresponding to where the user ended dragging.
    • Event Object event - The mouse event.
  • Return
    • Nothing
  • Scope
    • Client
onEventClicked​
  • Description
    • Called when the user clicks on a scheduled event. Use event.clickCount to detect double clicks.
  • Parameters
    • int itemID - The ID of the equipment item of the event that was clicked on.
    • int eventId - The ID of the event that was clicked on.
  • Return
    • Nothing
  • Scope
    • Client
onEventDropped​
  • Description
    • Called when the user drags and drops a scheduled event. It is up to this script to actually alter the underlying data to reflect the schedule change.
  • Parameters
    • int eventId - The ID of the scheduled event that was moved.
    • int oldItemId - The ID of the item this event was originally correlated against.
    • int newItemId - The ID of the item whose schedule the event was dropped on.
    • Date oldStartDate - The original starting datetime of the event.
    • Date newStartDate - The new starting datetime of the event.
    • Date newEndDate - The new ending datetime of the event.
  • Return
    • Nothing
  • Scope
    • Client
onEventPopupTrigger​
  • Description
    • Called when the user right-clicks on a scheduled event. This would be the appropriate time to create and display a popup menu.
  • Parameters
    • int itemId - The ID of the equipment item of the event that was right-clicked on.
    • int eventId - The ID of the event that was right-clicked on.
    • Event Object event - The mouse event that caused the popup trigger.
  • Return
    • Nothing
  • Scope
    • Client
onEventResized​
  • Description
    • Called when the user drags the edge of an event to resize its time span. It is up to this script to actually alter the underlying data to reflect the schedule change.
  • Parameters
    • int eventId - The ID of the scheduled event that was resized.
    • int itemId - The ID of the item this event is correlated against.
    • Date oldEndDate - The original ending datetime of the event.
  • Return
    • Nothing
  • Scope
    • Client
onPopupTrigger​
  • Description
    • Called when the user right-clicks outside of an event. This would be the appropriate time to create and display a popup menu.
  • Parameters
    • int itemId - The item ID of the equipment line that was clicked on (if any).
  • Return
    • Nothing
  • Scope
    • Client
