Box and Whisker Chart
A chart titled "Box & Whisker Chart" with a Value axis and two categories, Lot A and Lot B. Each category shows a Granite box in blue and a Limestone box in red, where the top and bottom of each box mark the 3rd and 1st quartiles, a horizontal line inside marks the median, and whiskers extend to the maximum and minimum outliers. A color-coded legend appears below the plot.
Component Palette Icon:
Box and Whisker Chart component palette icon
A Box and Whisker chart displays pertinent statistical information about sets of data. Each box represents a set of numbers. The upper and lower bounds of the box represent the 1st and 3rd quartiles. The line inside the box represents the median. The extends of the "whiskers" represent the max and min outliers. For a more detailed description, see http://mathworld.wolfram.com/Box-and-WhiskerPlot.html.
The configuration for setting up a box and whisker chart, like most charts, is populating the Data property. The dataset for a box and whisker chart contains sets of numbers. Each column defines a series of values, for which a "box" will be calculated. The column headers define the name for the box. You may also have an optional first column that is a String column, which can break up the series into categories.
Properties​
NameDescriptionProperty TypeScriptingCategory
AntialiasDraw with antialias on? Makes text smoother.boolean.antialiasAppearance
BorderThe border surrounding this component. NOTE that the border is unaffected by rotation.Border.borderCommon
Category Axis TitleA text label to display on the category axis.String.categoryAxisTitleAppearance
Chart TitleAn optional title that will appear at the top of the chart.String.titleAppearance
CursorThe mouse cursor to use when hovering over this component.int.cursorCodeCommon
DataThe data driving the chart.Dataset.dataData
Data QualityThe data quality code for any tag bindings on this component.int.dataQualityData
Fill Boxes?Fill the boxes with their color?boolean.fillBoxesAppearance
FontFont of text on this component.Font.fontAppearance
Legend?Show a legend on the chart?boolean.legendAppearance
Mouseover TextThe text that is displayed in the tooltip which pops up on mouseover of this component.String.toolTipTextCommon
NameThe name of this component.String.nameCommon
Plot BackgroundThe background color for the plot.Color.plotBackgroundAppearance
Series ColorsThe colors to paint each box in a series.Color[].seriesColorsAppearance
Tooltips?Show tooltips on tasks?boolean.tooltipsBehavior
Value Axis TitleA text label to display on the value axis.String.valueAxisTitleAppearance
VisibleIf disabled, the component will be hidden.boolean.visibleCommon
Scripting​
Scripting Functions​
This component does not have scripting functions associated with it.
Extension Functions​
Event Handlers​
Customizers​
This component does not have any custom properties.
