system.file.getTempFile
Creates a new temp file on the host machine with a certain extension, returning the path to the file. The file is marked to be removed when the Java VM exits.
system.file.getTempFile(extension)
StringextensionAn extension, like ".txt", to append to the end of the temporary file.
String - The path to the newly created temp file.
All
Example #1
# This code writes some data to a temorary file, and then opens that file. Assume that the data variable holds the contents of an excel (xls) file.
filename = system.file.getTempFile("xls")
system.file.writeFile(filename, data)
system.net.openURL("file://" + filename)
