system.file.openFiles
New in 7.9.5
Shows an "Open File" dialog box, prompting the user to choose a file or files to open. Returns the paths to the files that the user chooses, or None if the user canceled the dialog box. An extension can optionally be passed in that sets the filetype filter to that extension.
system.file.openFiles([extension], [defaultLocation])
StringextensionA file extension, like "pdf", to try to open. [optional]
StringdefaultLocationA folder location, like "C:\MyFiles", to use as the starting location for the file chooser. [optional]
List of Strings - The paths to the selected files, or None if canceled.
Client
Example #1
# This code would prompt the user to open files of type 'gif'. If None is returned, it means the user canceled the open dialog box.
paths = system.file.openFiles('gif')
if paths != None:
# do something with the file
Example #2
# This code would prompt the user to open files of type 'pdf' from their stored documents folder. If None is returned, it means the user canceled the open dialog box.
# Note: the computer running this code needs to have network access to the "fileserver" computer.
path = system.file.openFiles('pdf', '\\fileserver\PDF_Storage')
if path != None:
