system.file.getTempFile
Descriptionβ
Creates a new temp file on the host machine with a certain extension, returning the path to the file. The file is marked to be removed when the Java VM exits.
note
This function is scoped for Perspective Sessions, but since all scripts in Perspective run on the Gateway, the file must be located on the Gateway's file system.
Syntaxβ
system.file.getTempFile(extension)
Parametersβ
| String | extension | An extension, like ".txt", to append to the end of the temporary file. |
Returnsβ
String - The path to the newly created temp file.
Scopeβ
Code Examplesβ
Example #1
# This code writes some data to a temporary file, and then opens that file.
# Assume that the data variable holds the contents of an Excel (xls) file.
filename = system.file.getTempFile("xls")
system.file.writeFile(filename, data)
system.net.openURL("file://" + filename)
