SQL Table Joins
Overview​
The SQL JOIN allows you to run a single SELECT statement that references multiple tables. This can be used for more advanced filtering, as well as combining data from multiple tables in a single result set. The process of joining two tables involves stating both tables in the query, and then specifying that a column from one table relates to another in some way.
Joins may look imposing at first, but they are simply SELECT statements that utilize columns from multiple tables.
The JOIN keyword works in conjunction with a SELECT statement. However, there are some key concepts that must be addressed when attempting to use the JOIN keyword.
Specifying Each Column​
When listing column in a statement that uses the JOIN keyword, you must denote which table each column is being retrieved from. You can do this by using an Alias, or with the fully qualified column name. This prevents ambiguous columns in the context of the query, and makes it easier for you to use other keywords in the statement: i.e., adding WHERE clauses that apply to multiple tables.
Pseudocode - Fully Qualified Column Name
table_name.column_name
Declare the Relation​
After the JOIN keyword, you must state which columns from each table relate to each other. This is accomplished by stating the name of the table, using the ON keyword, and then stating that a column on the first table is equal to a column on the second table. The columns specified are typically primary keys for their respective tables.
In the example below, we're stating that the values in some_column on tableA should be associated with matching values in some_other_column on tableB.
Pseudocode - Using the Join Keyword
FROM
TableA
JOIN tableB ON tableA.some_column = tableB.some_other_column
The order you present the columns after the ON clause does not matter: A = B is equivalent to saying B = A, so we could switch the columns listed with no distinguishable impact on the resulting query
Combining the Concepts​
Altogether, a basic JOIN looks like the following:
Pseudocode - Join Syntax
SELECT
tableA.column,
tableB.column
FROM
tableA
JOIN tableB ON tableA.identity_column = tableB.identity_column
Joins with Three or More Tables​
Joins can even be done between three or more tables. The syntax is similar, with each new table relation declared below the first.
SELECT
tableA.column,
tableB.column,
tableC.column
FROM
tableA
JOIN tableC ON tableA.identity_column = tableC.identity_column
Join​
The standard JOIN, also referred to as INNER JOIN, will only return rows where the joined columns contain matching values. If one of the joined columns contains a value that is not present in the in the other, then the row is not represented in the result set. You would use JOIN when you only want results that are represented in both tables.
This section will demonstrate the various uses of the JOIN keywork. For the sake of clarity, the queries will run against tables that look like the following:
Products Table​
idproduct_name
1Apples
2Oranges
3Grapes
4Plums
Inventory Table​
idproduct_idquantityproduct_vendor
1115Apple Corp
2225Orange Ya-Glad
3356Grape Escape
4545Banana Solutions
Join in Action​
In this demonstration, only rows that pertain to Apples, Oranges, and Grapes are being returned. We're using a JOIN between products.id and inventory.product_id, so our results will only contain rows that have matching values from both of those columns. Our result set does not contain any information on products with products.id values of 4 or inventory.product_id values of 5, because those values are not present in both of the joined columns.
SQL - Joining Products and Inventory
SELECT
products.id
,inventory.product_id
,products.product_name
,inventory.product_vendor
,inventory.quantity
FROM
products
JOIN inventory ON products.id = inventory.product_id
Example Results​
idproduct_idproduct_nameproduct_vendorquantity
11ApplesApple Corp15
22OrangeOrange Ya-Glad25
33GrapesGrape Escape56
Left Join​
Return all rows from the left-most table (table A in the diagram), even if there are no matches on the right-most table (table B). If there isn't a matching record in the right table, then NULL values are returned.
Left Join in Action​
Here we see all rows returned from our products table (since it is the left-most table in our query). In row 4, columns that are being populated via the inventory table (product_id, product_vendor, and quantity) contain NULL values, because there isn't a row on the inventory table that matches with a product_id value of 4. The query must return something in this case, so it returns NULL for these columns.
SQL - Left Joining Products and Inventory
SELECT
products.id
,inventory.quantity
FROM
products
LEFT JOIN inventory ON products.id = inventory.product_id
Example Results​
4NULLPlumsNULLNULL
Right Join​
Return all rows from the right-most table (table B), even if there are no matches on the left-most table (table A). If there isn't a matching record on the left table, then NULL values are returned.
Right Join in Action​
When using a RIGHT JOIN, all rows will be returned from the inventory table. The products table does not have a row that contains an id value of 5, so the id and product_name columns will show NULL values in our result set.
SQL - Right Joining Products and Inventory
SELECT
products.id
,inventory.quantity
FROM
products
RIGHT JOIN inventory ON products.id = inventory.product_id
Example Results​
NULL5NULLBanana Solutions45
Full Join​
The FULL JOIN returns all rows from both tables, regardless if there are matching values in the joined columns. You would use a FULL JOIN in cases where you want to show all applicable records from both tables, and synchronize the data across both tables via the joining columns where possible.
Full Join in Action​
Note that we're using the same query as the standard JOIN, but we've prepended "FULL" to the last line of the query. Note the NULL values returned in cases where our product ID is not fully represented on both tables.
SQL - Full Joining Products and Inventory
SELECT
products.id
,inventory.quantity
FROM
products
FULL JOIN inventory ON products.id = inventory.product_id
Example Results​
4NULLPlumsNULLNULL
Full Joins in MySQL​
MySQL does not have an equivalent FULL JOIN. However, you can emulate one by utilizing a LEFT JOIN, RIGHT JOIN, and the UNION keyword. For the sake of simplicity, we will return all columns in the following example, but you would still want to specify individual columns in both SELECT query.
SQL - Full Join in MySQL using Left Join, Right Join, and Union Keyword
SELECT * FROM products
UNION ALL
WHERE products.id IS NULL
