system.security.validateUser
Tests credentials (username and password) against an authentication profile. Returns a boolean based upon whether or not the authentication profile accepts the credentials. If the authentication profile name is omitted, then the current project's default authentication profile is used.
Syntax (Client)​
system.security.validateUser(username, password, authProfile, timeout)
StringusernameThe username to validate.
StringpasswordThe password for the user.
StringauthProfileThe name of the authentication profile to run against. Optional. Leaving this out will use the project's default profile.
IntegertimeoutTimeout for client-to-gateway communication. (default: 60,000ms)
boolean - false(0) if the user failed to authenticate, true(1) if the username/password was a valid combination.
Client
Syntax (Gateway)​
StringusernameUser name to validate. Required.
StringpasswordUser's password. Required.
StringauthProfileAuthorization profile to user for validation.
IntegertimeoutNot used in gateway scripts.
boolean - True if valid username/password combination.
Gateway
Example #1
# This would require the current user to enter their password again before proceeding.
currentUser = system.security.getUsername()
password = system.gui.passwordBox("Confirm Password")
valid = system.security.validateUser(currentUser, password)
if valid:
# do something
else:
system.gui.errorBox("Incorrect password")
