system.security.validateUser
Descriptionβ
Tests credentials (username and password) against an authentication profile (User Source). Returns a boolean based upon whether or not the authentication profile accepts the credentials. If the User Source name is omitted, then the current project's default authentication profile is used.
Syntax (Client)β
system.security.validateUser(username, password, [authProfile], [timeout])
Parametersβ
| String | username | The username to validate. |
| String | password | The password for the user. |
| String | authProfile | The name of the authentication profile (User Source) to run against. Leaving this out will use the project's default profile. [optional] |
| Integer | timeout | Timeout for Client-to-Gateway communication. Default is 60,000ms. [optional] |
Returnsβ
Boolean - False if the user failed to authenticate; True if the username/password was a valid combination.
Scopeβ
Vision Client
Syntax (Gateway)β
system.security.validateUser(username, password, [authProfile])
Parametersβ
| String | authProfile | The name of the authentication profile (User Source) to run against. Optional. Leaving this out will use the project's default profile. [optional] |
Returnsβ
Scopeβ
Gateway, Perspective Session
Code Exampleβ
# This would require the current user to enter their password again before proceeding.
currentUser = system.security.getUsername()
password = system.gui.passwordBox("Confirm Password")
valid = system.security.validateUser(currentUser, password)
if valid:
# do something
else:
system.gui.errorBox("Incorrect password")
