Version: 8.1
system.security.lockScreen
Used to put a running client in lock-screen mode. The screen can be unlocked by the user with the proper credentials, or by scripting via the system.security.unlockScreen() function.
system.security.lockScreen([obscure])
BooleanobscureIf true(1), the locked screen will be opaque, otherwise it will be partially visible. [optional]
Nothing
Vision Client
Code Example​
Code Snippet
# This would run in a timer script to lock the screen after 15 seconds of inactivity, and then log the user out after 30 seconds of inactivity.
if system.util.getInactivitySeconds() > 15 and not system.security.isScreenLocked():
system.security.lockScreen()
elif system.util.getInactivitySeconds() > 30:
system.security.logout()
